Entering dimension text manually
Message 1 of 11
I used to work on an auto cad that is programmed to ask me to enter the dimension text whenever I enter a new dimension which is very useful for me because some times I want to add suffix or prefix as required. however, I don't know how to activate this feature can anyone assists me on this matter?
Replies (10)
Message 2 of 11
pendean
Community Legend
Community Legend
What version of AutoCAD are you using?
And which one did you used to use?
Message 3 of 11
I'm using 2016 student version
And the previous one was 2015 full version
Sent from my iPhone
Message 4 of 11
Patchy
Like this?
That was a way to make "Error" dimensions
Message 5 of 11
pendean
Community Legend
Community Legend
So nothing changed between these two versions as far as dimensioning goes: what dim commands are you using and were using in the older version?
Are you in a file from 2015 that worked thew way you want?
Otherwise, as noted above, what the commandline and enter T when prompted, or double-click on the dimension text after creation to edit.
Message 6 of 11
i'm not sure about the one that you showed me but I can describe the steps I used to do
1- Select the dimension command
2- Select first and second point
3- Here auto cad asks me what text to show in the dimension text box so I write for example "1200 mm"
Message 7 of 11
As far as I remember I used the typical dim command and regarding your second question I didn't get the full idea can you rephrase it please?
Message 8 of 11
Patchy
You typed in additional mm or 1200 mm ?
Many here would tell you that is the Override way and that's an invitation for huge mistake.
Why didn't you add the mm in Dimstyle?
Message 9 of 11
scot-65
For item #3, the dimension was non-associative and EXPLODED!
Look into DIMASSOC. 1 or 2 should be the norm.
Forever ditch that thought about DIMASSOC being 0 and apply your
prefix or suffix in the properties palette (Text override). To maintain
associativity, place the greater-than / less-than symbols somewhere inside.
Example: <> micro millimeters
If you wish to have a permanent prefix or suffix, look into DIMPOST and
incorporate into a (unique) dimension style.
If the dimension values are not what you expect, then do a better
job with your drafting practices. Do not investigate DIMRND to
solve this.
Exploded dimensions is cause for employee termination over here.
And Welcome to these Forums.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Message 10 of 11
I would type 1200 mm, 1.2 m, N.T.S or anything I want and it would show in the text box instead of the actual dimension.
Message 11 of 11
Alfred.NESWADBA
are you speaking about dimensions or about (parametric) constraints?
Second one allows you to show an object similar to a dimension and then enter a value to change the size of that object .... (but that's not a dimension)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
