Anuncios
Enter name of customization file to load:
No aplicable
Once a open the CAD file, it shows the box of Enter name of customization file to load: as attached.
So the batch plot cannot be run regarding this issue.
Do everyone know how to solve it?
Thank you.
0 Me gusta
Responder
Soluciones aceptadas (1)
11.213 Vistas
28 Respuestas
Respuestas (28)
jayhar
Replaced Your user profile or create new profile and replacing project paths
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
No aplicable
Yes, it is <1>
0 Me gusta
No aplicable
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-c...
I followed by this to change my user profile and changed the project path, but the problem still persists...
0 Me gusta
jayhar
Profiles & Project path. already you visit project path
see this Create different profiles Click here
and try, go to Option >Profile> add to new find the attachment
or reset profile
Check the System Requirement section.
Check the compatible AutoCAD service pack and install it.
cadffm
Solución aceptada
Use a file explorer to search a string in file contents(!important!)
Search for :
s::startup-loaded
This feedback in you commandline is not part of a standard installation, also the question for a menu file.
Search in all Supportfolders(options/files).
C:\programfiles\autodesk
C:\Users\<username>\appdata\
Perhaps you will find the source of this 3.part program.
Sebastian
0 Me gusta
No aplicable
or reset profile
I tried all of these, but the problem still persists...
How can I do these??
Thank you.
0 Me gusta
No aplicable
I searched for :
s::startup-loaded
in these two paths
but cannot find any thing...
Thank you.
0 Me gusta
cadffm
Hmm. Far away from your system i can not help so well.
Try it again, make sure the file explorer is also searching in hidden files,
this time search only for S::STARTUP
And search in all support folders in your options /files.
My hints 2.&3. in my answer here - https://forums.autodesk.com/t5/autocad-forum/enter-name-of-customization-file-to-load/m-p/8314825#M9...
You should copy&paste these lisp statements into your commandline, have you done this and only acad2015 appears? Ok.
And this: (findfile "acad.fas") or (findfile "acad.vlx") ?
Search also for this files:
Open your CUI command dialog,
start with the first cuix (acad.cuix?).
Where is the file stored?
Go into this folder and search for <samenameascuixfile>.MNL
For the acad.cuix example: ACAD.MNL
Do this for all loaded cuix files.
Main, Enterprise, all partial cuix.
And if nothing help we create a new profile, but first we are searching for the real source problem.
Sebastian
0 Me gusta
No aplicable
it shows the following files as attached.
Yes, it is acad.cuix
It stores in:
C:\Users\xxx\appdata\roaming\autodesk\autocad 2015\r20.0\enu\support\acad.cuix
 But in that folder, it just has acad.mln and AecArchxOE.mnl as attached.
 In my CUI command dialog, it just has All and Main Customization Files as attached.
