End an infinite loop (end a command) after certain time
Message 1 of 15
AUTODESK should create a simple command that will end any command after a user-defined time.
Can you make a script for that?
With my computer configuration, I would probably set the time to 10 seconds, because any command that runs more than 10 seconds on my computer is an endless loop, and I would probably need to force close the program and lose data.
Replies (14)
Message 2 of 15
pendean
Community Legend
Community Legend
Why not fix the reason your AutoCAD hangs and freezes all the time instead?
Your AutoCAD variant and year version as listed in ABOUT command is what?
Your Windows OS is what?
Your video card is what?
Otherwise... Customization forums are here to help you code whatever you want if it is possible, Autodesk is never going to do what you wrote https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
Message 3 of 15
JTBWorld
What commands are you having problem with?
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
Message 4 of 15
I don't believe you can fix the reasons 😄
I would say that the reason AutoCAD is slow is because of single core limits.
I use Autocad 2019 Civil 3D with
Windows 10
intel i7 8700k
Quadro P2000
which are close to the top of available equipment.
The biggest problems arise with commands like trim or selection commands (because I sometimes select too many objects --- my drawings sometimes have more than 200 000 objects).
Thank you for the suggestion to visit the customization forum. I will sure do that.
Message 5 of 15
jbtworld it doesn't really matter what commands are used because this isn't a topic about that, it's a topic to end any command after a certain time.
I read all the "advices" for trim, etc... "zoom in", "turn off object snap" etc etc... They are not the help I want at this time.
Message 6 of 15
Alfred.NESWADBA
Would cause my system to never save files ... I can't agree to that wish.
If your workstation/AutoCAD/drawing is slower than you expect we can go into details what happens when and try to find the source of the issue.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 15
ВeekeeCZ
Yeah... I know the issue.
Sometimes I forget that I should change my usual workflow and use BREAK rather than TRIM and if TRIM then pick a certain boundary rather than to all.
Usually, it's not an infinite loop. It just takes a ridiculous mount of time to finish the job.
ADSK should take care of it. Can't imagine a 'script' that could do that.
Message 8 of 15
JTBWorld
In that case you should really talk to your reseller or Autodesk support to see why this happens and how to avoid it, as a program to cancel commands like this would not be possible to create.
Jimmy Bergmark
Message 9 of 15
ВeekeeCZ
There is no other solution than try to change the workflow. If you record your doing eg. by SCREENCAST we could try to suggest something. Some workarounds..
But ADSK is the only one who can fix this. Make possible reasonable work with a large number of entities.
Message 10 of 15
But I am suggesting a userdefined time. For instance, you can type "MENUBAR" and set a value of the function. Equivalently, you can do also this. Default is 0 which means: not applicable, and user can set any time he/she wants. I just said that for me it would be 10 seconds.
I believe the reason is just the size of the files. Some of them are around 100 MB with 200.000 polylines/3dpolylines/...
Message 11 of 15
jbtworld why wouldn't it be possible to create?
In any programming language you can solve this problem with three lines
"if iteration_number>1000
stop_command
end"
(1000 as an example)
And that is very very simple. I bet you can also set that to use a time variable.
Message 12 of 15
JTBWorld
You need to suggest this to Autodesk one way or another, this is a user forum for peer support.
Jimmy Bergmark
Message 13 of 15
JTBWorld
Autodesk can fix it but a 3rd party developer can't fix this. Autodesk is not reading this or at least you can't count on that they do.
Jimmy Bergmark
Message 14 of 15
Alfred.NESWADBA
Ever thought about supporting such a system, knowing that not only professionals are sitting in front of the system?
Some user turns that to 0.01sec ... and he will not be able to use that variable any more.
>> stop_command
>> end"
...and half of your points are now imported to your Civil 3D surface, but the surface is not rebuild yet ... that's not a valid point to stop anything. And it does not make sense to stop it because you need all points to be used inside the surface...
It's like break the service of your car at 30min ... even if the old engine oil is out, but not a new one filled in. Does not make sense.
And as you might already have seen in AutoCAD or your Civil 3D, even an undo needs more time than the command execution itself to bring back what you had before.
- alfred -
Alfred NESWADBA
Message 15 of 15
Kent1Cooper
@Anonymous wrote:
But I am suggesting ....
This is not the place.  Go to the >Product Feedback page<.
Kent Cooper, AIA
