EMPTY LAYERS
EMPTY LAYERS
skipwillmuth
Observer Observer
EMPTY LAYERS
skipwillmuth
Observer
Observer
I'M A NEWBY TO ACAD, TRYING TO LEARN ABOUT LAYERS.  A BLUE STATUS ICON IN THE LAYER PROPERTIES MANAGER INDICATES THE LAYER IS NOT EMPTY. HOWEVER, IF I CREATE A NEW BLANK, EMPTY LAYER, IT'S STATUS ICON IS BLUE. IT SHOULD BE GRAY, WHICH INDICATES AN EMPTY LAYER.  MY UNDERSTANDING IS THAT IF A LAYER IS NOT EMPTY IT CANNOT BE DELETED, BUT MY NEW BLANK, EMPTY LAYER IS EASILY DELETED.  I DO NOT UNDERSTAND!
Alfred.NESWADBA
welcome @Anonymous.autodesk.com!
Which AutoCAD version and service pack do you use?
And is the system variable LAYERUSAGE active or not (if this variable is not active the layers-in-use are not evaluated at all).
I have tried it with AutoCAD 2016 SP1, when I create a layer (without making it active) the layers usage icon color is grey.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
skipwillmuth
Observer
Observer
Alfred, Thanks for getting back to me. I just purchase ACAD LT 2016 two weeks ago. My registration documents do not indicate which service pack I have. I am not familiar with layer usage. When I type layer usage I get a prompt to enter a new value. How do you activate layer usage? In the last few minutes, I have played around with new layers, and they now display a grey icon. I don't know what I had done earlier that was different. Thanks again for your help, Skip Sent with MailTrack
Alfred.NESWADBA
Start command _ABOUT ... and in that dialog you can see what service pack is installed.
You can always use the help, whenever you have started a command then press <F1> and you'll get details.
If the variable LAYERUSAGE is set to one then you are correct, then the icon should have the correct color.
Well, that's one method to get something solved. But hard to say now what you should do if that happens again (besides of "Play with your AutoCAD" 😉 )
- alfred -
Alfred NESWADBA
