Embedded PDF won't Load
I'm having an issue where there is a pdf that is embedded in a file that I'm trying to open, but the PDF doesn't load. It gave me an error message the first time, saying that I had to install some AutoCAD PDF loader or something, but now I don't get that message. Any help would be appreciated. I'm on 2019 version
pendean
Community Legend
Community Legend
Do you have access to the source PDF file?
Ask the file creator to send it to you, your embedded image may be corrupt.
Thomas_Stuehle
Hello @Anonymous
Do I understand it correct that the PDF is still listed under file references?
If so you would see the paths where the application expects the PDF file to be stored. If the PDF is non existent on your machine, please get in contact as @pendean to request the file.
If the PDF is stored on another location of your system you change the path in the context menu when selecting the file in the XREF Manager.
Did the post help you and answered your question?
If yes, feel free to click on the button "Mark as Solution". Thus also other users can benefit from the information. In case you still need help please feel free to provide an update here so we as Community know how we can help you best moving forward.
Best regards,
Thomas
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Thomas Stühle
Technical Support Specialist
