AutoCAD Forum
Embed an xref into the drawing
8 REPLIES 8
Message 1 of 9
rogersmi87
6579 Views, 8 Replies
I need to embed the files that are refernced in a drawing into the actual drawing. That way, if the path is broken they will still be visible.
I know this will make the drawing larger, but that really isn't an issue. The referenced file is a mrSid and I am using Autocad Map 2015 with the Carlson Civil Suite addon.
Tags (3)
8 REPLIES 8
Message 2 of 9
Kent1Cooper
in reply to: rogersmi87
XREF, Bind option.  You are aware, I hope, that once you Bind an Xref in, it will no longer update if the source drawing is changed, as it will if you don't Bind it.
Kent Cooper, AIA
Message 3 of 9
braudpat
Hello
+1 with Kent
If the default BIND option is not OK for you,
please change the System variable BINDTYPE ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 4 of 9
rogersmi87
in reply to: Kent1Cooper
Hello!
For some reason, I can't bind the Mr. Sid files. It is not that they don't work, but that the Bind command just isn't there.
What would I change the BINDTYPE to?
Message 5 of 9
pendean
You can't bind image files that way: you will need to clip them out inside an image viewer program first, then paste then into AutoCAD. You may lose resolution with this method. Binding mrSID files is a terrible idea for the most part due to loss of resolution.
Good luck.
Message 6 of 9
Kent1Cooper
in reply to: pendean
@pendean wrote:
You can't bind image files that way....
Ahhh....  I had assumed they were talking about Xrefs, but the original message isn't specific about the file type.
Kent Cooper, AIA
Message 7 of 9
rogersmi87
I did say it was a mrSid file in the original post.
Message 8 of 9
Kent1Cooper
[... which I didn't recognize as a file type, being unfamiliar with the designation and whatever makes them.]
Kent Cooper, AIA
Message 9 of 9
braudpat
Hello
Sorry I have "followed" Kent so I have not understood you were speaking only about .SID (or .ECW) raster files !
Happy New Year and THE HEALTH, Regards, Patrice
Patrice BRAUD
Forma Design Contest
