Elevation de/in/crease lisp
BB8x
BB8x
Hello
I need a lisp to change elevation.
Situation1: I have 3d poly/line and want to change evevation of some vertexes. I grab first, keying in value -.2 and vertex goes down for 0.2. Grabbing another vertex, keing in -.3 and vertex goes down for -0.2
Situation2: I grab text, keying in -.89 and text's elevation goes down for -0.89
0 Me gusta
Responder
548 Vistas
6 Respuestas
Respuestas (6)
paullimapa
Have you tried the Properties palette Geometry section where you can enter a Z value for elevation?
Paul Li
IT Specialist
@The Office
0 Me gusta
RobDraw
Maybe you can ask over in the LISP forum.
Rob
0 Me gusta
Kent1Cooper
@BB8x wrote:
.... want to change evevation of some vertexes. I grab first, keying in value -.2 and vertex goes down for 0.2. ....
.... text, keying in -.89 and text's elevation goes down for -0.89
Are you talking about grip-editing, and by "grab" do you mean you pick on a grip [so that it turns red], whether that's a 3dPolyline vertex or a Text insertion point [or anything else]?
If so, when you pick on the grip it goes into Stretch mode.  To change the elevation of whatever it is, you can type in a relative displacement, but it needs all three coordinates, in this case including 0's for X and Y and ending with the Z which will change the elevation.  To lower a 3DPolyline vertex by 0.2 drawing units, select the Polyline so the grips are showing, grab a vertex grip, and type in
@0,0,-.2
No routine is necessary.  One could be written if that's too much work.  But you would need to start the command to use it, by typing its name in, or picking a Tool Palette button, or something.  That may be as much work as typing in the @0,0, part in grip-editing, which doesn't require you to be in a command at all.
Kent Cooper, AIA
BB8x
Hi All
I understand what you have written about properties and @0,0,... comment, but I have loads vertexes and texts to drop down. Would take days so I need speed up
0 Me gusta
Kent1Cooper
Further questions:
In Situation 1, what do you picture as the procedure?  You call a command, and the User does...?  Select a 3DPolyline first, and then pick on a vertex grip and be asked how much to change its elevation?  Pick at a vertex directly, without picking the Polyline first?  More than one vertex adjustment within one running of the command?  If so, a separate request for distance for every vertex, or all that you select adjusted by the same distance?  Etc., etc.
In Situation 2, by "text's elevation" do you mean the Z coordinate of the object's insertion point [that's really easy], or is it about numerical text, and you want to change the number represented by the text's content?  [Or both?]
Kent Cooper, AIA
0 Me gusta
BB8x
Select a 3DPolyline first, and then pick on a vertex grip and be asked how much to change its elevation? - Yes
the Z coordinate of the object's insertion point [that's really easy] - Yes
or is it about numerical text, and you want to change the number represented by the text's content? - No content change, just elevation
0 Me gusta
