Electrical Data Extraction
bedyr
Message 1 of 11
bedyr
I am an electrical engineer and I am drawing power and lighting plan. Can anybody help me to do this ?
Replies (10)
Message 2 of 11
imadHabash
Hi and Welcome to AutoDesk Forum,
>> Can anybody help me to do this ?  <<
just type EATTEXT command and start learning how to do it.be patient and do it step by step till you finish it.
Good Luck..
Imad Habash
Message 3 of 11
bedyr
Good Luck..
I know that but I dont know how to add wire number to table.
Message 4 of 11
john.vellek
Hi @bedyr,
Is ti possible to attach some sample files showing me what you are dealing with? I am happy  to help you with some data extraction.
John Vellek
Message 5 of 11
bedyr
at first I am drawing a line and then I insert any electrical symbol attribute hung on line. I give a number to line with multileader. I want to extract data with electrical symbol name, power, line number and count. I can extract symbol name, power and count but I cant extract line number with hung on symbol. Thank you so much for your answer.
Message 6 of 11
bedyr
like that attachment photo.
Message 7 of 11
pendean
Community Legend
Community Legend
"data extraction" required blocks with attributes in AutoCAD first: may I ask why you are not using a dedicated version of AutoCAD like ELECTRICAL or MEP? these abilities are built-in.
Message 8 of 11
bedyr
Autocad electrical for schematic. and  I couldnt calculation wire voltage drop or current  on autocad mep. I am drawing any bulding lighting plan.
Message 9 of 11
pendean
Community Legend
Community Legend
Got it.
Extraction requires blocks with attributes: not text, mtext or leaders with text. basically what you have now has no 'intelligence' to it, you will need to manually create a table with manual entries.
EDIT: have you explored DATAEXTRACTION command? Works with text objects (not sure about mleaders).
Message 10 of 11
bedyr
I am doing it manually. But it must be an easy way. I also working with block attribute. I want extract data hung on line  with wire number. I know I need an attribute to give me block position. For example x block position is 1 (multileader number. When I think about that it is very easy to do this. But practically is difficult :((
Message 11 of 11
bedyr
