Electrical Data Extraction
bedyr
bedyr
I am an electrical engineer and I am drawing power and lighting plan. Can anybody help me to do this ?
Replies (10)
imadHabash
Hi and Welcome to AutoDesk Forum,
>> Can anybody help me to do this ?  <<
just type EATTEXT command and start learning how to do it.be patient and do it step by step till you finish it.
Good Luck..
Imad Habash
bedyr
Good Luck..
I know that but I dont know how to add wire number to table.
john.vellek
Hi @bedyr,
Is ti possible to attach some sample files showing me what you are dealing with? I am happy  to help you with some data extraction.
John Vellek
bedyr
at first I am drawing a line and then I insert any electrical symbol attribute hung on line. I give a number to line with multileader. I want to extract data with electrical symbol name, power, line number and count. I can extract symbol name, power and count but I cant extract line number with hung on symbol. Thank you so much for your answer.
bedyr
like that attachment photo.
pendean
Community Legend
Community Legend
"data extraction" required blocks with attributes in AutoCAD first: may I ask why you are not using a dedicated version of AutoCAD like ELECTRICAL or MEP? these abilities are built-in.
bedyr
Autocad electrical for schematic. and  I couldnt calculation wire voltage drop or current  on autocad mep. I am drawing any bulding lighting plan.
pendean
Community Legend
Community Legend
Got it.
Extraction requires blocks with attributes: not text, mtext or leaders with text. basically what you have now has no 'intelligence' to it, you will need to manually create a table with manual entries.
EDIT: have you explored DATAEXTRACTION command? Works with text objects (not sure about mleaders).
bedyr
I am doing it manually. But it must be an easy way. I also working with block attribute. I want extract data hung on line  with wire number. I know I need an attribute to give me block position. For example x block position is 1 (multileader number. When I think about that it is very easy to do this. But practically is difficult :((
bedyr
