Editing Rows and Columns in AutoCAD
RalphBrown99
Message 1 of 12
RalphBrown99
Hi:
I am editing a table that was created originally in Excel but the change is that big that I had to detach the Excel Source and unlock all the cells. Now I have to add and delete rows and columns. Adding or deleting rows is not a problem, the options are available every time I do click in any cell, the problem is when I am trying to add or delete columns: The options in the contextual menu are not available.... how come?
Just in case you know the reason in how is possible to edit rows but not possible to edit columns, please let me know. I have to edit the table using the 2 options. I am adding a .png file so you can have a better idea about was going on
Thank in advance
Ralph
Replies (11)
Message 2 of 12
TheCADnoob
The only way i have been able to duplicate this behavior is by having data links intact.
Would you be able to provide a file so that we can look at it?
CADnoob
Message 3 of 12
john.vellek
Hi @RalphBrown99,
Does this behave differently if you select the column header cell instead of a data cell?
I too would like to see a sample file if you can attach one.
John Vellek
Message 4 of 12
RalphBrown99
Hi John and "TheCADnoob":
It looks that the same is happening if I choose either a cell or a column header. For sure I am sending the file that opens in Paper Space with the table on it. Please have a look and let me know your comments
Thanks in advance
Ralph Brown
Message 5 of 12
TheCADnoob
your column headers are all still locked and linked.
CADnoob
Message 6 of 12
RalphBrown99
Hi CADnoob, thanks for your time.
I was able to unlock the column but I still have problems to break the link. In the most of the tables that I have worked before, I do right click>Data Links>Detach Data Link
In the file that I sent you I do no have this option available.
I am sending you 2 .png so you can see the difference in between the option available in the first file and the option not available in the second file
Again, thanks in advance
RM
Message 7 of 12
TheCADnoob
Yea, i saw the same thing the other day. For the size and content of the table i think you might be better off just recreating the table. (Use MATCHPROP to get it close to the table you currently have) It seems like something is screwy with it. I have seen some elements get corrupted before, like view ports, but i haven't heard of table doing it but id imagine if a viewport can do it so could other elements.
If re-starting the table is not an option you can create a new link and re link the table and then you can regain the ability to add remove rows and columns but the screwey link issue will live on.
CADnoob
Message 8 of 12
john.vellek
Hi RM,
Can you try removing the link using the Data Link Manger?
John Vellek
Message 9 of 12
TheCADnoob
There are no links in the Data Link Manager of the file he uploaded Smiley Sad
CADnoob
Message 10 of 12
john.vellek
Hi @RalphBrown99,
Try this please:
Remove the DXE file
type this in the command line: (dictremove (namedobjdict) "ACAD_Datalink")
Then close the drawing and reopen it
John Vellek
Message 11 of 12
john.vellek
Hi @RalphBrown99,
I am checking back to see if my post or others helped you with your problem.
Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please select the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 12 of 12
RalphBrown99
Hi John:
Thank you very much for your help. I know that it was long time ago but just now I could see that the solution is working very well.
Thanks again
Rafael
