Anuncios
Editing block color to 'by layer' but it doesnt change the color
jdborgeson
Community Visitor
jdborgeson
Community Visitor
Community Visitor
I am trying to make this arrow block change color.  When I changed the multileader color, the arrow stays this green color.  I assume this is because of something to do with the block.  when I go to the block editor and try to set the arrow color to by layer (you can see the layer is red), the arrow refuses to change color.
0 Me gusta
Responder
270 Vistas
2 Respuestas
Respuestas (2)
pendean
Community Legend
Community Legend
What is the object color (and more importantly layer) defined for that INSIDE the block? BYBLOCK settings work better more often that not vs just "bylayer" in most circumstances.
0 Me gusta
vinodkl
Hello @jdborgeson
From the snapshot shared I could see that there is another block named "arrow" inside of block editor making it a nested block. Use the command "explode" to explode the block named "arrow" so that it takes the color which your are assigning. I hope that solves your problem :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 Me gusta
