Editing attribute with multiple tags individually
No aplicable
We have purchased an add on program, AMOD8, which has proved useful in batch editing of attribute blocks on multiple drawings. In the program you identify the block and the attribute tag in a script file. The program then applies the script file to the identified drawing files.
I want to use the program to edit the attributes of revision blocks on a series of drawing.
The problem is that each revision block has multiple tags that are identical such as Revision Number, Date, Etc.
Is there a way to specifically target an attribute from multiple attributes with the same tag?
0 Me gusta
Responder
728 Vistas
4 Respuestas
Respuestas (4)
chriscowgill7373
Even in Lisp programming, there is no way that I know of to edit attribute tags when they are the same, unless you know the specific handle associated with each one, which varies in every drawing.  Have you contacted the developer of this app to see if they have a solution?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
No aplicable
I have not but will give that a try.
0 Me gusta
JTBWorld
If I understand your problem correctly our app JTB BatchAttEdit would be able to work for you. There is a free trial available so you can try first.
Jimmy Bergmark
JTB World - Software development and consulting for CAD and license usage reports
https://jtbworld.com
0 Me gusta
No aplicable
Thanks for the tip
0 Me gusta
