Editing a number
Editing a number
No aplicable
I have about 500 spot elevations on a drainage plan and need to subtract 1.55 from each elevation. Can this be done globally or I am stuck editing each one by hand? HELP
0 Me gusta
Responder
618 Vistas
6 Respuestas
Respuestas (6)
rkmcswain
What are these 'elevations'? Attributes? Text? Mtext?
0 Me gusta
Jay_B
If they have a Z value & all points need to move by -1.55, then the MOVE command will work.
Command: MOVE > Select Objects > specify base point > 0,0,0 > Enter > specify second point > 0,0,-1.55 > Enter.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
0 Me gusta
No aplicable
The elevations are text. I do not need to move them i need to minus out 1.55 from each. For example if the elevation is 10.6 it will change to 9.05
0 Me gusta
Jay_B
Can you post the dwg here?
C3D 2018.1
C3D 2016 SP4
0 Me gusta
3wood
You can try ALTEXT and get your task done with only a few clicks.
Settings as below:
0 Me gusta
rkmcswain
Give this a shot.
(defun c:addval ( / inc ss ent obj str num i)
  (setq inc (getreal "\n Enter increment: "))
  (setq ss (ssget '((0 . "MTEXT,TEXT"))) i 0)
  (repeat (sslength ss)
    (setq ent (ssname ss i))
    (setq obj (vlax-ename->vla-object ent))
    (setq str (vla-get-TextString obj))
    (setq num (distof str))
    (vla-put-TextString obj (rtos (+ num inc) 2 2))
    (setq i (1+ i))
  (princ)
It will accept a negative value for the increment.
If you are not sure what to do with lisp code, see this.
0 Me gusta
