I am trying to make a plot tab what show Plot Date, Plot By and Drawing Path. I got the Plot Date and Drawing Path but I am having a hard time with Plot By. I am using field (field category is login) and it has my full name. if I use Last Save By it use my ID Number. is there a way I can get my ID number to be used as Plot By
>>I am trying to make a plot tab what show Plot Date, Plot By and Drawing Path<<
Are you talking about the plot stamp?
Can share a screenshot, so that we can look into it.
@Cassidy243 hi,
if under plot field category login is not what you are after then you could user other category LispVariable
in your acad.lsp (or acaddoc.lsp) add this code line:
(setq id-number "Brian Cassidy")
back in field dialog box:
other field category, select LispVariable and select id-number from the lisp variable list.
enjoy
Moshe
