Edit Block in Place toolbar missing
Message 1 of 10
When"ediiting a block in place"I don't see the toolbar i used to see in 2014.
Replies (9)
Message 2 of 10
leothebuilder
Do you mean the contextual ribbon when you are in the block editor?
Message 3 of 10
No. In 2014 I would get a floating toolbar.
Message 4 of 10
leothebuilder
Do you mean a tool palette for block editing?
If so, in the block editor on the contextual tab at the top click on "Authoring Palettes" button to open the tool palette.
Message 5 of 10
i also found the same issue (version 2014.)
i have not been able to get the toolbar to show up & the ribbon is missing the close command.
you can use bclose to get a dialog box to save or discard and it shows you the name of the block
Message 6 of 10
nestly2
When you installed 2014, did you settings from a previous version?  If so, you may have to add the missing features manually via the CUI editor, otherwise
Resetting AutoCAD to default will likely remedy both issues.
Message 7 of 10
also my MTEXT toolbar is missing.
how do i re-set autocad to default ?
Message 8 of 10
nestly2
 Try MTEXTTOOLBAR = 1 at the Command line
 The blue text in the post above is a link with instructions.
Message 9 of 10
MTEXTTOOLBAR = 1
DID IT
THANKS
Message 10 of 10
JBerns
I would like to have the opposite toolbar appearance setting. In other words, do not display the Refedit toolbar when editing a block in place. Let me know if I should start a new thread.
The Refedit toolbar appears when REFEDIT command is active. A user wants to suppress this action because he already has a custom toolbar that contains the Refedit, Add, Remove, Save, and Discard buttons. (Didn't need the block name drop-down box)
After installing 2019 last year, customizations were applied such that the toolbar did not appear or pop-up during REFEDIT. New, higher res monitors were acquired recently and something seems to have reset. Now, the Refedit toolbar appears during the REFEDIT command.
In the CUI, I have checked:
  • Double-Click Actions > Block : it's set to Xref and Block, Edit Reference In-Place
  • Toolbars > Refedit : Default Display = Do not add to workspaces
The Ribbon is on, but collapsed.
MTEXTTOOLBAR = 1
I cannot find a setting or system variable to suppress the Refedit toolbar when editing in-place.
I hope someone may have an answer to suppress the Refedit toolbar appearance persistence.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
