Edit AutoCAD table from Excel or Text file
Amriya_Exe
Amriya_Exe
I created Table in AutoCAD layout as shown below I have to edit cell values which highlighted in red for all layouts.
Any way to do automatic from excel/text file?
Second request is
For all layout in reference details I am writing this location span number manual.
I know the Field command CTAB but I need only last 6 digits from Layout name.
cadffm
Field
Diesel
Getvar ctab substr getvar - strlen
https://www.theswamp.org/index.php?topic=48156.0
Sebastian
Amriya_Exe
$(substr,$(getvar,DWGNAME),1,14)
I have to paste this command in my table CELL?
cadffm
No, you have to activate your cell, rightmouseclick -> Insert Field
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-1B6DD22B-10D1-44ED-BAA2-E6D79FE52327
In Field dialog, choose category DIESEL (or Diesel Expression?) and there is a place to paste this code.
>>"$(substr,$(getvar,DWGNAME),1,14)"
1. This code reads your DWGNAME variable, you talked about the CTAB variable.
2. This will read the first, not the last characters
3. 14 characters instead 6
for you:
$(substr,$(getvar,CTAB),$(-,$(strlen,$(getvar,CTAB)),5),99)
Read more about DIESEL, it's useful: [F1]
Sebastian
Amriya_Exe
Any update for first query
