We are currently using autoCAD LT and are looking to upgrade to autoCAD 2015 so that we can draw over the top of our aerial photography. Are aerial photograpghy is a .ecw file. From what I have gathered is that autoCAD will be able attach this image to the drawing through the external reference command however it will not be georeferenced to its location. This isnt a problem but I was wondering if autoCAD will still insert the image at the scale it was taken without the georeferencing?
Hello
Welcome to the Autodesk/AutoCAD Forums !
ACAD LT is not able to insert/load ECW,SID,etc image files ...
With ACAD Architecture, ACAD MEP, ACAD Mechanical, ACAD Electrical, etc, you can insert ECW, SID files
but the image will not be inserted automatically at the right position !!
With ACAD MAP & ACAD CIVIL the ECW, SID image will be inserted automatically at the right position !!!
So if you know somebody with an ACAD MAP or CIVIL , he could for you :
1) Insert automatically at the right position the ECW, SID file
2) Save the DWG file to Ascii/Text DXF file
3) Use an editor to change the image extension from .ECW to .JPG and resave the DXF with an other filename
4) Convert the ECW/SID file to .JPG (with low compression to keep quality)
5) Now you can load the New DXF (and the .JPG image) with ANY ACAD - With ACAD LT for example ...
Patrice BRAUD
AutoCAD (vanilla) can attach the images but getting it in the correct location and scaled right can be an issue. You can use Raster Design with AutoCAD and make it work better but I would suggest using AutoCAD Map3D or Civil3D depending on the type of work you do.
Hi Andre,
Please post this in the >>>Civil 3D Forum<<<.
Dave
Dave Stoll
Las Vegas, Nevada
If you want to use plain AutoCAD and if you have added the ECW support (through Civil 3D, Rater Design or an external plugin), you can place/georeference your .ECW images according to their .EWW world files - use the GeoRefImg plugin (free) from Autodesk Apps or from https://www.cadstudio.cz/en/apps/georefimg/
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
