eci loading is slow in AutoCAD
RockyBrown4134
Message 1 of 8
RockyBrown4134
Dean;
Just for curiosity, I have notice the same issue. How long does it take to load these? I have let the "loading" go on for over five minutes. Still has not loaded. Here is a screen capture.
 Could my Enterprise CUI file cause a problem? It says its already loaded.
Thanks.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
Replies (7)
Message 2 of 8
john.vellek
Hi @RockyBrown4134,
I wonder if it slow on loading or if you have a different issue such as problems with your licensing authorization. Take a look at this article and see if it pertains to your issue.
John Vellek
Message 3 of 8
RockyBrown4134
John;
Tried all of those. Did not help. I let the program run for an hour and a half before canceling it out.
Good article though.
FYI.....What is calling the AeciIb applications?
Rocky Brown
Message 4 of 8
pendean
Community Legend
Community Legend
Content in your files are calling for these applications: see this topic https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Errors...
Message 5 of 8
RockyBrown4134
That did it. There was a Raster Design folder that did not get uninstalled from an earlier version.
Thanks Dean!
Rocky Brown
Message 6 of 8
RockyBrown4134
I will not tag this as a solved post since it was not my original post.
Rocky Brown
Message 7 of 8
Hi @pendean,
thanks. I'm gonna try if the solution proposed solves my problem.
Thanks again.
Message 8 of 8
Hello, I have the same issue and I tried both solutions but  none of them helped me
I have Autocad 2017 and it doesn't go further than loading after the checking license.
