Dynamically move default insertion point with block
I've created a block that is a leader with dynamic text on top and bottom with the leader line going between the texts.  I added stretch and move parameters so I can stretch the leader line will either stretch the arrowhead side or stretch the text side.  The default insertion point is at the center of the text line at (0,0,0).
My problem is once I stretch the text side the default insertion/move point stays put where it started and doesn't move with the stretch.  I've tried changing the insertion point (0,0,0) to the arrow side but the same issue happens when i move the arrow side.  I can not select or see the default insertion point in the block editor to include in any move/stretch action, I just know it is at the (0,0,0) mark.
Anyway to edit this point to move with the block as it gets stretched either way?
I've attached the block.
imadHabash
your problem will be solved if you add a Base point parameter to the block definition .
Imad Habash
