Dynamic input not switching dimensions with tab key
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi, I recently upgraded from AutoCAD 2023 to AutoCAD 2024 and my functionality using Dynamic Input no longer allows me to press the tab key to switch dimensions. I have dynamic input enabled and DYNMODE is set to 3. I have tried other DYNMODE variables and those do not allow me to use TAB either. It works if I use the comma to switch dimensions but I want to use the tab key, using the comma hides object dimensions and defeats the purpose. It does not appear that this functionality has been removed, as the Dimension Input Settings dialog box still has a light bulb saying to "Press TAB to switch to the next dimension input field".
What am I missing here?
