Dynamic Input For Lines Starting with a Snap Not Working
Yehoshua.Shore
Yehoshua.Shore
When trying to draw a line starting with a snap, I want to spcify a defined length of the line with dynamic input. However, when starting that line with a snap, the dynamic input feilds dont appear after selecting the first point. Tried changing DYNMODE to all values, and its not working.
Help would be apcirated,
Thanks!
- Yehoshua
0 Me gusta
Responder
Soluciones aceptadas (1)
851 Vistas
8 Respuestas
Respuestas (8)
imadHabash
I suggest to to try from DSETTINGS command >> Dynamic Input tab , any changes ?
Imad Habash
0 Me gusta
Yehoshua.Shore
Thanks. But nothing in those settings seems to help.
0 Me gusta
Moshe-A
@Yehoshua.Shore  Shalom,
Just did what you described and it works so maybe describe exactly what are you doing (which osnap?) and i'll test it again.
Moshe
0 Me gusta
Yehoshua.Shore
The Autocad Licence I am usings is under my boss's name, and it wont allow me to upload a screen cast to my account. So heres a link to the screen cast which will illustrat the issue. https://knowledge.autodesk.com/community/screencast/9b837879-c87f-498c-86ea-eb355d1208e0
0 Me gusta
Moshe-A
@Yehoshua.Shore ,
watched the video but can not understand what are you tring to do? maybe you are tring something and call it direct input but it is not?
"direct input" means you type a distance (just a number) and AutoCAD place the point at that distance in the crosshair\rubberband angle, does this work for you?
Moshe
0 Me gusta
imadHabash
Solución aceptada
I'm afraid that your objects has a Z axis value ( Elevation ) !! check this matter ?
Imad Habash
Yehoshua.Shore
That was it! Thank you so much  @imadHabash!!
It's crazy how something can elude you and drive you crazy for hours, when the answer was so simple. Thank you, thank you. Have a great day.
imadHabash
You're Welcome :cara_con_una_leve_sonrisa:
Imad Habash
0 Me gusta
