dynamic coordinate chart
john.taiariol
Message 1 of 14
john.taiariol
I would like to create a coordinate chart that is dynamically linked to a polyline in such a manner in that if I was to move a coordinate on the polyline then the chart would automatically update. I was wondering if this is possible using ordinate dimensioning? thanks in advance for your help.
Replies (13)
Message 2 of 14
murray-clack
I would put a circle on each of the pline's vertices (on a "no plot" layer), and in the table, you can add field where you would use the OBJECT option (select the circle, and then extract the X & Y coordinates from the center of the circle.  Then, when you need to change the location on the pline's vertex, you can drag both the pline grip and the center of the circle grip at the same time, and when you REGEN, the table will update
Message 3 of 14
john.taiariol
not sure how to link the table cell to the coordinate
Message 4 of 14
murray-clack
Place your cursor inside the cell, right-click and select "Insert Field", and the FIELD dialog will appear.  Click the field category pull-down menu and select "Objects", then select "Object" in the Field Names list, and then click on the cross-hairs button under the "Object" category and then select your circle
Message 5 of 14
john.taiariol
works thanks. kinda long drawn out process. anyway this can be automated with a lisp routine?
Message 6 of 14
murray-clack
Message 7 of 14
john.taiariol
yes I saw this one but it doesn't quite work for me. I was hoping for a lisp routine to generate a table of coordinates by selecting a polyline.
Message 8 of 14
murray-clack
Message 9 of 14
john.taiariol
I am trying to run your 71_CoTbl.Fas from the website you recommended and getting this error “File D:\Box.tbl is already open.; error: quit / exit abort”
Message 10 of 14
john.vellek
HI @john.taiariol
Did you get the LISP routines as suggested by @murray-clack to work for you? If not, I suggest going to the Author's site for assistance with his routine.
John Vellek
Message 11 of 14
john.taiariol
still doesn't work. I tried to get help from the author website but have not received a reply yet.
Message 12 of 14
john.vellek
Hi @john.taiariol,
It does look pretty slick on the web site but I didn't get it to work either. Please add a post if the author gets back to you.
John Vellek
Message 13 of 14
john.taiariol
I am not getting a response from this website. Do you have any suggestions?
Message 14 of 14
john.vellek
Hi @john.taiariol,
In the past I have made a block with fields to capture the coordinates of each Vertex. It sounds like it is laborious but it goes pretty fast depending on the complexity of your file.
Give this a try and attach a sample file to a post if you want me to look too.
John Vellek
