Dynamic Block with Stretch Action
Hello All, I am creating a standard blocks for our company, A section bubble cut that can rotate, flip and stretch. One problem for the Stretch action is that it just stretch horizontally only. When i rotate the block to different angle using rotate action, the stretch action is not working. I have uploaded the file. Did i do something wrong? or mis-step something? Thanks, Dennis
There's no file uploaded, so I can't fiddle with it. One thing you can try, if it's only a couple that needs it, is to BURST the block. This will essentially explode it, without losing all the properties. Then you can stretch/alter it how you want.
Somehow i could not upload the file? Could i have your email address?
Jason.Piercey
Did you include the stretch parameter with the rotate action?
Yes, i have figured it out. I didn't include the stretch parameter in the rotate action last time. Now it works! Thank you
Jason.Piercey
You're welcome
