dynamic block with menu drop down
Hi I'm trying to build a dynamic block for a plan view of a crane I'm trying to give it a drop down menu that would cover any lengths at a half m(0.5m) increment starting from 4 m to 33 m. I am unsure on how to do that or even how to create that in general. any guidance into this matter would be greatly appreciated.
scot-65
Try asking in the Dynamic Blocks forum.
Sounds like a linear parameter tied into a stretch action with a lookup hook.
(33 - 4) x 2 = 58 lookup lines. Are you sure you want to do this?
There is a way to set up a minimum/maximum/increment linear parameter
similar to SNAP (not osnap). I would tie a dimension line to this as part
of the DB and locate on layer Defpoints so it can be seen and not printed.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
nrz13
By far the easiest thing to do would be to make a dynamic block and just use the stretch action on a linear parameter.  You can limit the parameter to any lengths you want and it's an incredibly simple dynamic block.  However, how that works depends on how the longer crane is intended to look (does the angled part stay the same or stretch, do the ends both stretch out as well, or just one end, etc.).
In order to get the best help, reattach your block with what it looks like at one or two more sizes so we can determine the best option for you.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 64GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
ara_neresesian
HI
please upload the file which shows 0.5 m crane and  33 crane
and note the area you want to starch
is it like this?
