Dynamic Block table User defined Parameters not deleting with block table
GeeHaa
Message 1 of 9
GeeHaa
Hi
I created a dynamic block with a block table with user defined parameters. I no longer needed the block table so I erased it but the user defined parameters are still showing in the properties window. How can I remove these?
Replies (8)
Message 2 of 9
john.vellek
HI @GeeHaa,
Can you attach your block to a post? I am curious to see if I can get rid of the parameters for you.
John Vellek
Message 3 of 9
Did you erased it in Block Editor?.
Try to edit it in Edit block In-place.
Then Custom block properties will be broken and then recreate it to New Block.
Message 4 of 9
GeeHaa
unfortunately it has several visibility states that would also be lost with a refedit but I guess its probably my best option though.
Message 5 of 9
GeeHaa
In the block table I had a user parameter named ConnectorTYpe and even thought the block table was erased it still shows up in properties
See Attached.
Message 6 of 9
john.vellek
Hi @GeeHaa,
I used the block editor to look at your block.I used the Parameters Manager to see the User parameters. I selected the ConnectorType, Rt-clicked and selected Delete Parameter. I then closed the Block Editor. Does this work for you too?
John Vellek
Message 7 of 9
GeeHaa
Thanks! That works.
I was not aware of the Parameters Manager
Message 8 of 9
charlesXB5AM
I dont get the window that you shown when i click parameter manager all i get is a white window under properties that stays for like a second and then disappears
Message 9 of 9
pacifierY83DN
In the "Block Editor" window, type the command 'Parameters', you will be sure to see the Parameters Manager panel where you can easily delete un-wanted user-defined parameters.
