Dynamic Block Equal Array
Jake_CAD
Message 1 of 8
Jake_CAD
Dear all,
I wish to incorporate an array function to distribute the balusters equally across the width, when the width is adjusted.
Using the attached block as a working example, does anybody have advice?
Kind regards,
Jake
Replies (7)
Message 2 of 8
TheCADnoob
I was able to approximate the behavior. It's a two grip process instead of just the one.
I added a line that ran the length of the wall and then a constraint Parameter to it.
I started an array from scratch using the array command.
Then I defined two User Parameters. One called Count and one called Mid
I set Count equal to round(d1/1987.5)+1 this took the distance of the wall and devided it by the distance between the center of the first and second column in your block. Then it rounds it up and adds one. This gives you the total number of columns that will be needed.
I set Mid equal to ((d1-350)/(Count -1)) which is the distance of the wall (minus the end space) divided by the number of columns needed.
I then used Count and Mid in the Array parameters
Now you just drag the wall and then drag the distance parameter.
CADnoob
Message 3 of 8
Gil_C
Bingo!!😎
Digital Design Manager | Technology Consultant | CITE User Group Leader | AUGI Advisory Board Member
Message 4 of 8
Gil_C
Good job
Message 5 of 8
Jake_CAD
That is fantastic, thank you.
Thank you also for the concise method explanation.
Message 6 of 8
TheCADnoob
Glad it works for you, happy to help!
CADnoob
Message 7 of 8
rp_cad_2025
Can someone help me, please?
I am trying to have a dynamic block with different visibilities (caster sizes). I want the supports to show as I increase the size of the base, evenly spaced. Also, to add more casters after a specific size. Please see attached for reference. Thank you in advance!!
Message 8 of 8
TheCADnoob
Given the example above, what have you tried?
CADnoob
