DXF read error on line 15638441. Invalid or incomplete DXF input -- drawing disc
No aplicable
i reopened a file that i saved a couple of days ago on autocad 2010 but it shows this error code. could anyone please help me with this it's a month worth of work. thank you..
0 Me gusta
Responder
Soluciones aceptadas (2)
5.607 Vistas
17 Respuestas
Respuestas (17)
Victoria.Studley
Hi @Anonymous,
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD Architecture forum!
Did you save this DXF file in AutoCAD Architecture 2010 or AutoCAD 2010?
Could you post the file here so that we can try to help you with it directly?
You might also try the suggestions in this article and those linked at the bottom of it:
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
No aplicable
Hello @Victoria.Studley and thank you for replying so soon
it was AutoCAD 2010 actually
i have tried opening it up using a text editor (Microsoft word, notepad, word pad ...) but they all bugged and wouldn't open, so i eventually had to force their closure, and the links in the bottom didn't work either (page not found)
is there anything else i could try?
I have read that the problem could be fixed by opening the file in a different AutoCAD version, 2006 for example, and saving it in another format or something but i don't have another version.
would it be okay if i attach the file so maybe you could take a look at it?
0 Me gusta
No aplicable
i couldn't upload the file maybe i can send it to you by e-mail?
0 Me gusta
Victoria.Studley
Hi @Anonymous,
I've moved your post over to the AutoCAD forum, since you're not working in AutoCAD Architecture.
Can you upload the file to a hosting service like Dropbox, Googe Drive, OneDrive, Box, etc.? You should then be able to share the link here for us to view the file.
Victoria Studley
Alfred.NESWADBA
A DXF file with 15mio lines is huge, create a ZIP from that and upload the ZIP file please.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
HI @Anonymous,
I sent a link to a shared folder on my A360 drive.  If you can upload your file and let me know that it is there, I am happy to take a look at this for you.
John Vellek
john.vellek
HI @Anonymous,
Did you get the invite to share my A360 folder? I was hoping to get this DXF problem worked out for you.
John Vellek
No aplicable
Hello everyone i'm sorry for not uploading the file i've been having some connectivity issues.
@Victoria.Studleyi am uploading the file to my google drive i will post the link as soon as it's done
@Alfred.NESWADBAyou were right it's huuge!! 144mo i actually didn't notice that haha
@john.vellekthank you i have received your invitation i will try to put it there as well but it depends on how well my internet is
0 Me gusta
No aplicable
update:
@john.vellek, i have droped the file at the drive you sent me and i got this, i don't know if it's done or not.
is this what i'm supposed to get if i opened the file with a text editor?
0 Me gusta
No aplicable
0 Me gusta
john.vellek
HI @Anonymous,
It does look your web browser has opened the DXF instead of uploading it.  I am using your other link to download the file and I will see if I can get this repaired for you.
John Vellek
No aplicable
Alright thank you!!!
0 Me gusta
john.vellek
Hi @Anonymous,
I opened your DXF in Notepad (it took a while) and I went to the end of the file.  There is no EOF (End of FILE mark) or even an End of Section.  This indicates that the data never completed writing to the file.
I used a search to find the first Section just before the end of the file. I then deleted all of that last incomplete section. This removed a whole 25 MB of data.  I added an EOF but I still didn't have any luck in importing this file into AutoCAD. I have another specialist looking at the file but I am not too hopeful.
Do you still have the original file it was created from or the BAK?
John Vellek
No aplicable
Hey i'm sorry for making go through all of this, i really appreciate your effort.
I do have the BAK file but it's big too so it's gonna take about an hour and a half to upload i will post the link as soon as it's done.
0 Me gusta
john.vellek
Solución aceptada
HI @Anonymous,
This is what was recoverable from your DXF. I hope this helps.
John Vellek
No aplicable
@john.vellekThank you for your help? it's missing a lot of data but i guess it's better than nothing at least i won't have to start all over again :cara_con_una_leve_sonrisa:
the BAK file finished uploading so here's the link anyway:
https://drive.google.com/open?id=1lQAYGqf8WCumhZTCgY94ZJ9AUv_nKU9R
0 Me gusta
john.vellek
Solución aceptada
Hi @Anonymous,
Thanks for the BAK file. I renamed the BAK to DXF and then opened the file in AutoCAD 2018.  I ran AUDIT and it found an enormous number of errors. I also ran PURGE and -PU>Regapps to further clean up the file.
Perhaps this file will be better than the one that had the bad DXF.
John Vellek
0 Me gusta
