I need to create CNC files from my model. In order to do this I have everything seperated into layers that I need to appear for the essentilas for these files. I am able to get out the correct CNC files that I need if I explode all of my dynamic blocks. What is happening is that if I do not explode I am getting all of the shapes that are contained within that dynamic block even though I only want the one that appears on the screen.
We are controlling the dynamic blocks with visibility states and layers. Basically there are for example 8 shapes that are within that nested dynamic block on my Holes layer. So on screen I am seeing the selected visibility state but when I create the DXF I am getting all of the shapes on that layer from all of the visibility states.
I would like to get away from exploding the blocks so that if in the future I needed to make a change I couls still have that option. So the question I have is how to I get out a DXF that actually only captures then layers, visibility states, and lines I visually see on screen.
As a note I have played around with freezing layers and this still does not work for me as I have the same results as listed above.
