.DXF Import Table Issue
jonnyjr
jonnyjr
I have never come across this before however, when trying to import a .DXF file into AutoCAD 2019 I am getting the below error message.
"Table name missing on line 402.
Invalid or incomplete DXF input -- drawing discarded."
I have tried opening the file with a text editor, copying the data into excel and looking at line 402, however I don't really know what I am looking at. One thing that puzzles me is that the file can't be corrupt as on my gmail account it shows a preview replicating what I expected to see in AutoCAD.
Any help would be greatly appreciated as I have searched through the forum trying to find an answer and tried the previously mentioned solutions of looking at the file in a text editor.
I cant upload the file here either for some reason.
"The attachment's su60 1a.dxf content type (application/x-dxf) does not match its file extension and has been removed."
Jon
S.Faris
Was the DXF prepared using Autocad? If so, did you try to make a DXF again and see if the problem persists? You can upload the DXF file to wetransfer and then post the link here.
Refer(you might have already) : Error: "Invalid or incomplete DXF input -- drawing discarded" when opening a DXF in AutoCAD
SALMANUL FARIS
jonnyjr
Hello Salmanul,
I am afraid I do not know the origin creator program. I thought all .DXF files were produced in AutoCAD. The files were sent to me so I did not produce them my self from .DWG master files.
I had referenced the post you linked to in trying to resolve the problem however I can not work out what the issue is on line 402.
Here is a link to the files I am having trouble with.
https://we.tl/t-4TrMuJweBG
Thanks for your help.
S.Faris
Refer to this previous thread on this matter : invalid or incomplete DXF input - drawing discarded
If the DXF was made using a non-Autodesk product, then it need to be corrected in the source file
SALMANUL FARIS
Pointdump
Jon,
I get same as you:
QGIS will open your DXF files, and re-saving them makes them openable in AutoCAD.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Alfred.NESWADBA
please find attached the repaired files (without warranty).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
jonnyjr
Thank you all for your help, I appreciate the solutions mentioned, along with the repaired files. I was struggling for a long time trying to sort it out.
Jon
