DwgConvert Read Error
ConquerorChivalrous
Observer Observer
ConquerorChivalrous
Observer
Observer
I am using the DWGCONVERT command to convert file from 2020 to (standard) 2014, when I covert some dwg files I receive error message that the following files could not be read
@Alfred.NESWADBA
paullimapa
Have you tried using AutoCAD to open that drawing in question to see if can be opened? Perhaps that dwg is corrupted and may require recovery or maybe that dwg doesn’t exist at all?
Paul Li
IT Specialist
@The Office
Alfred.NESWADBA
You are using AutoCAD 2014, this version of AutoCAD can't open a file that was saved with AutoCAD 2020 (which by default saves in DWG-2018 format).
You can download Autodesk DWG TrueView (which is free), here you can open newer files and save them back.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
