DWGCONVERT error
DWGCONVERT error
I am using the DWGCONVERT command to convert file from 2013 to 2007, and everytime I covert I receive error message that there was an unconverted file. I am using 2014. Also it alowed coversion if I converted to 2000 but not to 2007 format.
Replies (7)
Alfred.NESWADBA
The conversion log you showed does not show an error, it says 1 file converted, 0 errors.
So what message do you get (uploading a screenshot might bring up clarification).
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
Im not exactly sure what it said, but it was in red and said error could not convert file, but gave no reason. So I saved the error convert log.
Alfred.NESWADBA
then try it again ... or don't you get that message any more?
- alfred -
Alfred NESWADBA
Ok so the error says "The file can not be converted due to a sharing or disk write problem." This is a file sent to me from an Architect using 2007. I have been receiving files from this client for the past two years and have never had a problem, is this something I should worry about? Thanks for your time.
Alfred.NESWADBA
Not sure what you try to do with DWGCONVERT with that drawing, just open it and save it in the current format.
The message itself looks like you have the file open and try to overwrite it with the same name. If your DWGCONVERT-settings are configured to overwrite the original file then you can't have it open, start the command while you have just one emptry drawing open and select that file in the DWGCONVERT dialog ... is now the first guess.
HTH, - alfred -
Alfred NESWADBA
I was using it to see if a file was opened by an educational product due to the architects intern opening and saving files with his educational copy and I decided to try it on a list of files and I came up with that error. And no the file was not open at the time of the command. I just wanted to know if this is a problem I should be concerned with.
Alfred.NESWADBA
Try that with files that are new and stored on your local drive, e.g. in C:\TEMP (where you have full permissions).
If that results in the same problem then verify if you have the latest service pack installed.
What you can do additionally: login to your system with another Windows user and try it again, just to test the AutoCAD profile.
- alfred -
Alfred NESWADBA
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
