AutoCAD Forum
DWG TRUE CONVERT FOR OLDER SYSTEMS
7 REPLIES 7
Message 1 of 8
jackshield
13953 Views, 7 Replies
I am running AutoCAD2004 on a windows xp os (insert dust & dinosaur jokes here)
I have a dwg true convert program, but only convert down from 2007.  Is there a convertor that will read later version files for conversion that will run on xp?
7 REPLIES 7
Message 2 of 8
in reply to: jackshield
You might want to check out Draftsight.  It's free and may be a bit more capable than the 2004 version of ACAD.
Message 3 of 8
jackshield
thanks, but not looking to change software, just need to convert later versions back to my prehistoric software for use
Message 4 of 8
jggerth
I'd suggest trying Draftsight for the conversion....    Adesk's latest viewers/convertors are not likely to run on XP
Message 5 of 8
hwalker
in reply to: jggerth
Drawing Trueview 2014 does work on Windows XP. In their wisdom, my bosses have decided not to upgrade my OS from XP and I run Trueview 2014 just fine
Howard Walker
Left Handed and Proud
Message 6 of 8
jggerth
in reply to: hwalker
@hwalker wrote:
Drawing Trueview 2014 does work on Windows XP. In their {s} wisdom  ,{/s} my bosses have decided not to upgrade my OS from XP and I run Trueview 2014 just fine
FTFY 🙂
The only issue with that is getting 2014 TrueView now.  looks like the only download still on the Adesk website is for 2015.  And being copyrighted licensed software I can't redistribute it...
Message 7 of 8
pendean
DWGTrueview 2014 download links can be found in this post:
http://forums.autodesk.com/t5/Installation-Licensing/TrueView-download/m-p/4427763#M68123
Message 8 of 8
jggerth
in reply to: pendean
Thanks Dean!
”Boost
