Anuncios
dwg to pdf
654work
dwg to pdf
654work
I’m getting inconsistent results printing using dwg to pdf.  Same hatch patter, color… but pattern shows different on the same drawing, see attached.  I know there is a workaround for this but can not find it.  Any suggestions?
C3D 2017, SP 1.1
0 Me gusta
Responder
Soluciones aceptadas (1)
525 Vistas
7 Respuestas
Respuestas (7)
TheCADnoob
What process are you using to create the PDF?
are you using EXPORTPDF or are you using a PDF printer and if so which one?
CADnoob
0 Me gusta
chriscowgill7373
can you post the drawing?  although they may be the same pattern and color, are there any object overrides applied?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
0 Me gusta
654work
Using DWG to PDF to print.
0 Me gusta
654work
not sure I could just post them due to the size.  3 xrefs plus the dwg, about 10 mb
0 Me gusta
chriscowgill7373
you could zip them and try here, or upload them to A360 and share a link:
Here is some information on sharing a file via A360:
https://blog.a360.autodesk.com/a360-feature-share-files-easily/
A Screencast by Expert Elite Matt Wunch showing how to share a link:
https://knowledge.autodesk.com/community/screencast/093c8ca8-27a6-407e-8c0e-c6e555ab3b63
If you are sharing a drawing, please add it to a zip file first, as it reduces the need for A360 to process the file and makes the file quicker to access.
0 Me gusta
john.vellek
Hi @654work,
It is hard to tell from your attached image if the drawing is 2D or not.  I would like to see a sample drawing (it doesn't have to be the whole thing as long as it retains the issue at hand).
Please also attach your plot style CTB file.
John Vellek
0 Me gusta
654work
Solución aceptada
The issue appears to be resolved.  I used hatchtoback and this fixed the problem.  Below is a link to the discussion with the solution.
https://forums.autodesk.com/t5/autocad-forum/dot-hatch-pattern-not-displaying-properly-when-using-qu...
Thanks to all who were willing to help.
0 Me gusta
