Dwg to pdf
This widget could not be displayed.
Dwg to pdf
I want to make a dwg to pdf.
But if I want to search a text in PDF, it does not work.
I used command ctrl +f.
to plot i use standard AutoCAD pc3 file: dwg to pdf.
How can i solve this.
Thank u
Nasier
carl.coghill
@Anonymous, try the solutions described here;
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-create-selectable-and-searchable-text-in-a-PDF-from-AutoCAD.html
EDIT: Apollogies, I can also only select text not search text.
Carl Coghill
Senior Designer
AutoCAD 2018
Windows 7 Professional 64bit
LinkedIn
RobDraw
My guess is that you are not using TTF fonts. SHX fonts cannot be made searchable within AutoCAD. Some 3rd party PDF programs can do it, but the results can be sketchy.
Rob
rkmcswain
To clarify, I think that you mean to say that SHX fonts cannot be made searchable from within PDF viewers. In other words, the strokes of each character become vectors and not "text" inside the PDF.
If it helps any, Autodesk has created a way to turn this geometry back into text (at least with English), with the 2017.1 update for AutoCAD 2017.
R.K. McSwain     | CADpanacea | on twitter
RobDraw
Actually, I meant that AutoCAD can't make the .shx fonts searchable but some 3rd party PDF generators can as the OP wants the text searchable within the PDF.
Rob
