Anuncios
DWG to PDF with Merge Lines on and wipeouts - 2016 Not working
CADvisers
CADvisers
When plotting using DWG to PDF with Merge Control on Wipeouts are not working in 2016.  The lines show through the wipeouts.
However the same file in 2014 works correctly using the same .pc3 file.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
Responder
2.238 Vistas
11 Respuestas
Respuestas (11)
pendean
Community Legend
Community Legend
Did you migrate from 2014 to 2016? It probably moved over more than you expected.
Otherwise show us what you mean from 2014 and 2016 in PDF form.
0 Me gusta
CADvisers
Attached are images showing two identical plots with same settings having lines merge ON.
And these are "Wipeouts" not Background mask.  The whole reason for using the wipeouts for the last 15 years was to have the ability to have lines merge ON.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
CADvisers
After further research using a 3rd party pdf driver such as nuance PDF creator, the results are as expected from previous versions of DWG to PDF.
So it definately is the DWG to PDF.pc3 files for 2016.  All the extra, (may I say "junk") that has been added to the new DWG to PDF has caused more problems than it's worth.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
CADvisers
I'm seeing no improvement to this for 2017 either.
The long drawn out process just to get a pdf created correctly for companies that use lines merge with wipeouts.
1. Plot to DWF.
2. Convert DWF to a flattened tiff using Acroplot.
3. Then converting the tiff back to a PDF using Nuance or other 3rd party pdf converter.
Totally unacceptable when this technology had already worked in prior releases.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
pendean
Community Legend
Community Legend
Can you not use the DWFs, just skip PDFs?
See below using R2017, SP1, wipeout (and MTEXT as a side test), PDF result attached,  tell me what I did that you do not do, let's figure it out
0 Me gusta
CADvisers
Hmmm,  I might've mispoke with the last one.
I just recently installed Civil 3D 2016 sp3 and now it seems to be working on mine as well.
The DWF's are used internally for my client.  But when they send out files to their clients and/or contractors they flatten them so they open more efficiently.  It's more of a customer service item on their end.
Thanks for looking at this.
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
pendean
Community Legend
Community Legend
R2016 works fine too
0 Me gusta
CADvisers
Found the PROBLEM!!!!
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
pendean
Community Legend
Community Legend
That sure is a problem.
Looks like you need help from your C3D peers https://forums.autodesk.com/t5/autocad-civil-3d/ct-p/66
0 Me gusta
CADvisers
It's posted there too..
But this comes down to the change in how Autodesk handles pdfs.
this is same file plotted in 2014...
Jonathan Stewart
CADvisers
P.O. Box 7811
Lancaster, PA 17604
Ph. 717-468-3111
0 Me gusta
pendean
Community Legend
Community Legend
C3D changes with every year version, unlike plain AutoCAD and most of the other verticals that only change withe change in the DWG file format.
C3D is a unique bird with unique issues.
0 Me gusta
