I was working on a file last night and started plotting to pdf. I plotted out the first two sheets (which are the most complex), and everything went smoothly. I had to end my session for the night and wanted to continue this morning.
Started up AutoCad 2024 again and continued plotting, but then all of a sudden, all of my plots seem to hang at about 5-10% completion, AutoCad freezes for a few moments, but then pulls through with the job. So the jobs lasts up to 15s per sheet instead of the usual 1 or 2s.
The drawings and the file are small and not complex by any means, and this is now happening with all my files.
My laptop is a Lenovo Legion 5 Slim with Intel i7 and a RTX4060, so based on that, everything should run smoothly.
I haven't changed or tinkered with any settings compared to last night when everything was working fine.
What might be a solution?
P.S. I went through the other threads and tried the default solutions for this issue like the background plot setting etc. and nothing seems to work.
