AutoCAD Forum
DWG to PDF.pc3 | layer information not turning off!
17 REPLIES 17
Message 1 of 18
TMCoBIM
2960 Views, 17 Replies
Hi All,
I hope i can get some help here, At the moment when i use the publish command and select my .pc3 the pdf that gets spit out has ignored some of the settings, one of which that is becoming a issue is layer information being included. I have attached Image 'Plotter PDF Settings' which shows my settings image 'Layer Information' shows what happens when i pdf with the .Pc3.
The only way i can get it to not include layer information is running is with the settings in image 'Publish Settings', Due to how we run our department we wish to not do it this way. Can anyone give me a way to fix this?
john.vellek has embedded your image(s) for clarity
17 REPLIES 17
Message 2 of 18
Jay_B
in reply to: TMCoBIM
Have you tried turning off the Layer information in Publish Options?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 18
pendean
Did you actively edit the PDF PC3 file? Plot/pagesetup settings do not carry over into PUBLISH once you choose the PDF override as you did in your posted screenshot.
If you want to use your pagesetup aka "plotter pdf settings" then on your PUBLISH pop-up you have to select USE PAGESETUP instead of PDF override as you did.
Message 4 of 18
TMCoBIM
in reply to: Jay_B
In picture below you can see that it is turned off.
Message 5 of 18
TMCoBIM
in reply to: pendean
Hi pendean,
Yes that is how we normally plot with settings below, which has a edited .pc3 and thats the problem. for some reason it ignores the settingsCapture.PNG
Message 6 of 18
john.vellek
Hi @TMCoBIM,
Please tell the version of AutoCAD you are using. Is it fully up to date?
Please apply a named page setup to your file and then etransmit it so I can take a look.
John Vellek
Message 7 of 18
TMCoBIM
in reply to: john.vellek
Hi John,
Version is 2019 but does it on 2018 as well.
Etransmit attached.
Message 8 of 18
john.vellek
Hi @TMCoBIM,
I tried to duplicate this behavior in AutoCAD 2018. I opened your file, verified that the Layer settings  is not included and then used PUBLISH. The resulting PDF does not have the layers shown in the navigation pane.  What steps am I doing differently than you?
John Vellek
Message 9 of 18
TMCoBIM
Assuming you have the settings below and have A2PDF selected nothing. This is whats confusing me.
Message 10 of 18
john.vellek
Hi @TMCoBIM
What happens if you logon  as a new user to the computer? Make no customizations to AutoCAD at all except to make the CTB available. Do you see the same results?
John Vellek
Message 11 of 18
TMCoBIM
That seems to work, do you have an idea of what is wrong? @john.vellek
Message 12 of 18
john.vellek
Hi @TMCoBIM,
It appears that you have a damaged user profile. Try performing a Reset Settings to Default and I think that should correct the problem for you.
John Vellek
Message 13 of 18
TMCoBIM
Hi @john.vellek,
that did not work.
Message 14 of 18
john.vellek
HI @TMCoBIM,
It is unusual that a Reset did not take you back to original settings.  If you have your data backed up, you could remove the existing Windows account and then add it back in to see if that works.
John Vellek
Message 15 of 18
TMCoBIM
I dont have it backed up also the downtime with that is huge cost. Its weird cause sometimes it doesn't include layer randomly and also its does this on most of our CAD machines.
Message 16 of 18
john.vellek
Hi @TMCoBIM,
If this is happening intermittently then that is a different issue. What kind of customization have you done in your systems?  Are the plot drivers stored on the network per chance?
John Vellek
Message 17 of 18
TMCoBIM
They are stored on a server
Message 18 of 18
john.vellek
HI @TMCoBIM,
Ok - now we are definitely getting closer.  You either have some network latency or some network permissions issues (or both).  Try putting the files local to see if they behave. If so, then you need to try setting the network share as full permissions. If that fails then you likely have some network speed issues. IF it does work then you can try to tighten security on those folders.
Are those folders added to your Trusted path in OPTIONS?
John Vellek
AutoCAD Inside the Factory
