Anuncios
DWG to PDF not working
ss454_ls6
ss454_ls6
When I plot to PDF, I have always gone windowed/center plot, and 1:1 scale, however now it doesn't work correctly.
The project I am currently working on is 9.080x7.125 and if I try it in a 8.5x11 (portrait) it doesn't fit on the page, like not even close. I then rotated the project and put it in a landscape format, and while it then appears to fit, it actually comes out scaled. If I use Layout, it comes out extremely scaled.
I really don't understand why it has worked before. Please help. Thanks.
0 Me gusta
Responder
Soluciones aceptadas (1)
1.265 Vistas
9 Respuestas
Respuestas (9)
john.vellek
Hi @ss454_ls6,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I see that you are having problems with scaling when plotting with the DWG to PDF driver.  Can you share your file? If possible you could also include your plot style. I would like to see what you are experiencing in order to offer suggestions to resolve the issue for you.
John Vellek
0 Me gusta
pendean
Community Legend
Community Legend
So you don't use paperspace?
If it doesn't fit, what scale are you plotting to? 99% that is the issue.
0 Me gusta
ss454_ls6
I've uploaded the dwg and the pdf file in the version that scaled from selecting landscape.
0 Me gusta
ss454_ls6
I don't know what paperspace is. I'm selecting no scaling at all. Keeping everything at 1:1
However it auto scales for some reason. A 9x7 model should easily fit on a 8.5x11 paper, portrait or landscape.
0 Me gusta
john.vellek
Solución aceptada
Hi @ss454_ls6,
I made a short video for you that might help.
First I open your drawing and verify that the lines you have drawn are approx. 8x9.
Then I click on the tab at the bottom labeled Layout 1.
On it I have created a viewport on a non-plotting layer. This acts like a window to see into modelspace.
If I double click in this viewport (frame) I am put into modelspace.
I can zoom and pan as well as many other editing functions.
When I am in the model through this viewport, I go to the scalelist at the bottom right of the screen and select 1:1
I then also created a Page setup to configure how I want to plot this layout.
You can see how I picked letter size and a scale of 1:1
I have attached this file for you to examine. Please let me know if you have additional questions regarding this process.
John Vellek
0 Me gusta
ss454_ls6
I'm so impressed you were able to make a video so quickly. I looked through it and most of it brand new to me, so bare with me as I get the time to put the instructions into practice myself. Thanks
0 Me gusta
john.vellek
HI @ss454_ls6,
I hope that the video gets you started. Ask any additional questions on this issue in another post and I will try to walk you through getting them resolved.
John Vellek
0 Me gusta
john.vellek
HI @ss454_ls6,
I am checking back to see if my post helped you with your problem or question. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
ss454_ls6
Wonderful this does work. Thank you so much!
0 Me gusta
