Anuncios
DWG to PDF issues
DWG to PDF issues
No aplicable
When i use autoCAD's DWG-PDF, the final PDF which automatically opens is showing the circles within blocks (used to create the arc) which are on a frozen layer. For example circles on cooker hobs, wheelchair turning circles, rounded off edges (ghost circles) etc..
Can anyone shed some light on why this is? I am having to ask other colleague's in the office to do my PDF'ing.
Trev
0 Me gusta
Responder
Soluciones aceptadas (1)
1.512 Vistas
14 Respuestas
Respuestas (14)
Sofia.Xanthopoulou
Hi tremedesign,
and welcome to our community Emoticono feliz
Well, I cannot recreate what you are describing here. Maybe I misunderstood. Can you please provide the dwg file? And maybe some screenshots of your plot configuration? If it is too complicated for you to make the screenshot - a video will do it, to. You can use screencast for this task.
0 Me gusta
TheCADnoob
I am not see the described proble either Emoticono indiferente
CADnoob
0 Me gusta
No aplicable
thanks for the responses,
please see attached example where the issues have been bubbled.
thanks,
Trev
0 Me gusta
Alfred.NESWADBA
...and the drawing from which the PDF is created from?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
No aplicable
AutoCAD's DWG to PDF ePLOT
0 Me gusta
Alfred.NESWADBA
I (re-)asked to upload the drawing which was used to create this PDF as we need to see what object types these arcs/circles are).
>> DWG to PDF ePLOT
If that is the printer you used then please let us know the exact name, "DWG to PDF ePlot.pc3" does not exist by default ... or upload that PC3-file too.
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
I have attached a screen shot.
The name of printer/plotter is DWG to PDF .pc3 - Thats all it says when i plot an individual sheet to PDF
0 Me gusta
TheCADnoob
are your colleagues using the same 'printer' ?
CADnoob
No aplicable
You should upload dwg,tell us which version, install latest updates...
0 Me gusta
john.vellek
Hi tremedesign,
Which version of AutoCAD are using to create the plots?  Does the problem still exist if you log on as a new User with administrator permissions? How about if you Reset settings to Default?
Have you tried the AutoCAD PDF (General Documentation) PC3 file? Does it do the same thing?
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
0 Me gusta
No aplicable
AutoCAD 2017
Yes the problem still exists with admin permissions
Problem still occurs even after resetting to defaults
PC3 file is what i use to plot if you had read the previous messages.
0 Me gusta
Alfred.NESWADBA
as long as we don't have the drawing, so we can try it on our workstations and compare the results, ... all is nothing else than guessing.
And there could be so many settings that this guessing might use weeks (hard to follow a thread with multiple suggestions to look about which additional idea might also be tried).
Why don't you show the drawing (at least just the critical elements (as long as you can reproduce the issue)) ... that could then be a 1 minute solution (in best case).
- alfred -
Alfred NESWADBA
0 Me gusta
No aplicable
Solución aceptada
Issue solved. A simple un-install/re-install solution.
Can you please refrain from commenting on this post as i am getting slightly annoyed at these email notifications.
Trev
0 Me gusta
TheCADnoob
Please accept the response that best solved you problem as the solution.
If you wish to no longer recieve emails it may be a better approach to manage that in your 'Subscriptions and Notifications' section in your user profile.
CADnoob
