dwg to pdf error
dwg to pdf error
ALESSANDROSANVITALE6585
Message 1 of 11
dwg to pdf error
Hy.
See the attachement
Thank's
alessandro
Replies (10)
Message 2 of 11
rkmcswain
Are you aware that you are posting this in the .NET programming forum?
I'm going to put your image inline for easy viewing by others.
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 11
No, I'm not aware about the correct forum Smiley Sad? which is it?
Message 4 of 11
john.vellek
Hi @ALESSANDROSANVITALE6585,
This thread is now in the AutoCAD Community Forum (where it belongs).
Is it possible to share the dwg and plot configuration in a post?  I suggest in the mean time, you create a named page setup for this layout and verify that the papersize is available in the driver.
John Vellek
Message 5 of 11
paullimapa
Perhaps the specified paper sheet size 1100.00 x 600.0 MM does not exist?
What if you manually plot the dwg file?
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
Paul Li
IT Specialist
@The Office
Message 6 of 11
Hi John. Thank you for your reply.
No, always error even with a3....
I enclose the file.
But there's always a problem with all the files
Hi
Message 7 of 11
paullimapa
So if Dwg To PDF also errors when you manually plot any drawing, then perhaps the Dwg To PDF.pc3 file got corrupted.
Paul Li
IT Specialist
@The Office
Message 8 of 11
john.vellek
HI @ALESSANDROSANVITALE6585,
Your file prints fine on my side.  Which version of AutoCAD are you using?  I have attached my DWG to PDF PC3 file. Can you rename your existing one and try this instead to see if that corrects your problem? These files are from AutoCAD 2018 installation.
John Vellek
Message 9 of 11
Resolved. I replaced the file pc3 with an old version (2014). I attach the two versions (2018 bad, 2014 ok). Thank you all.
Message 10 of 11
So this is an AutoCad software package issue?
Has this been corrected?
I just had the same problem with new Laptop/Load.
Message 11 of 11
kevinpyle63
Community Visitor
Community Visitor
thank you for your solution, I have recently upgraded from Win7 2108 to Win11 Autocad2024 and have been creating a few dwg to pdfs to test out new computer without issue until today it started giving me errors. downloaded your 2014version and created pdf sucessfully.
thank you,
KP
