Dwg file decrease in size too small to edit?
So I am extremely new to AutoCad MEP. I am currently using the AutoCad MEP 2014 for HVAC and I'm also using Autocad 360.
But I've received a DWG file and it does open in Autocad, but its like the equipments and duct that I need to use is too big for the whole image itself. Say for instance, I try to add a VAV box or Diffuser and it literally takes up the whole file. Is it the file? or Can I somehow change the scaling of my equipment? I can't seem to figure out the problem. The file is from an older version of AutoCad, I believe its not compatible with the version I currently have.
Any suggestions or solution would help. Please and thank you
Post your dwg.
