DWF/pc.3 issues, or something...
TOMLANG7190
TOMLANG7190
Before I updated things and added Bluebeam printer drivers, I had my sheets set to "DWG to PDF.pc3", and, via sheet set manager, I could plot to either PDF or DWF without having to go in and change anything.  This is no longer the case.  I had to rebuild the DWG to PDF.pc3 driver, and that works fine, but I can no longer just automatically plot to DWF like I did before.  Can anyone shed some light on this?  Thanks!
0 Me gusta
Responder
193 Vistas
3 Respuestas
Respuestas (3)
rkmcswain
Do you have some screenshots showing what has changed?
How were you printing to PDF/DWF ? Via Sheet Set Manager? Via Publish?
0 Me gusta
TOMLANG7190
Plotting to PDF or DWF via sheet set manager.  In the past, in page set-up manager, I'd set the plotter to DWG to PDF.pc3.  From the SSM, I could publish to either PDF or DWF without changing anything.
I noticed that when I added the Bluebeam plotters, all the default ACad plotters disappeared, and I had to restore the DWG to PDF.pc3 one.
Is there a way to just restore all the original plotters?
0 Me gusta
pendean
Community Legend
Community Legend
Looks like you really need BLUEBEAM support over here
You can always remove your BlueBeam and/or RESET or REINSTALL AutoCAD to get everything back to OOTB. Your IT person/folks can help you with that if you're in a locked-up user account.
0 Me gusta
