Duplicate definition of block ... ignored.
htemizel
Message 1 of 16
htemizel
dear sir/madam,
when i insert a block with the same name i get this in the command bar:
"Duplicate definition of block GH ignored."
is there a way to get the related dialog box as prompt?
Thanks in advance.
Replies (15)
Message 2 of 16
S.Faris
Try using RENAME Command to rename the block before pasting it in to the drawing.
Refer to the link, If you need explanation on how to do it : LINK
SALMANUL FARIS
Message 3 of 16
htemizel
thank you for the answer. but the problem is i want to keep the blocks with their same names and there must be a dialog box asking me if i'd like to redefine the blocks with the same name. that dialog box is missing.
Message 4 of 16
S.Faris
In that case Rename first and then use BLOCKREPLACE
Refer to this : LINK
Or You can use one of this Methods : LINK
SALMANUL FARIS
Message 5 of 16
htemizel
thank you. that is an alternative way, true. but i'd like to learn how to get the prompt asking me if i'd like to redefine the block or not.
Message 6 of 16
jayhar
1. First you PURGE your drawings then past block.
2. If you want to redefine (overwrite) the existing definition of a block in your drawing, use the -INSERT click here
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly. If your issue persists,
Please give me a bit more detail on this issue so we can continue to work towards getting this solved.
Thanks You
Jayhar.M.J
Helpful Links: Prepare your computer for download |  Autodesk Virtual Agent | Clean Uninstall | AutoCAD randomly crashes or freezes
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Message 7 of 16
S.Faris
As far as I know, Currently there is no option as such in Autocad t the time being.
SALMANUL FARIS
Message 8 of 16
htemizel
hi,
thanks for the answer but it didn't work. i attached related files seperately (drawing7.dwg and drawing8.dwg).
i named the block as "Force". in drawing 7 and in drawing 8 the block names are same and "Force". i want to drag into drawing7 the block from drawing 8. but once i do this, the block is not changing but repeating itself.
Message 9 of 16
jayhar
Edited
<<<<<1. First you PURGE your drawings then past block.>>>>>
First delete the block of same name, PURGE your drawings then past block
Message 10 of 16
S.Faris
If you can post your Dilemma in the the Autolisp Forum, Guys in there might be able to help you.
SALMANUL FARIS
Message 11 of 16
S.Faris
Ok This is it 🙂 (I Hope So)
Solution:
  1. Open Drawing 8
  2. Type WBLOCK
  3. In the WBLOCK Pop-up Select BLOCK for Source(top of the window)
  4. Select FORCE from Drop-down
  5. now give the output filename as FORCE.dwg and WBLOCK it.
  6. Open Drawing 7
  7. type INSERT
  8. browse to FORCE.dwg
  9. Click OK
  10. Select REDIFINE
Tell me that it Worked, Please 😉 Smiley Tongue
SALMANUL FARIS
Message 12 of 16
Kent1Cooper
Use the AutoCAD Design Center [the ADC command, or just Ctrl+2] to bring it in.  Navigate to Drawing8, and pick the Blocks category.  Right-click on the Force Block thumbnail image, and you will be given the choice whether to put one into in Drawing7 using the current definition of it in Drawing7 [the "Insert Block..." option], or to change that definition to match that in Drawing8 and put another one in [the "Insert and Redefine" option], or just to change the definition to match that in Drawing8 without putting another one in [the "Redefine only" option].
Kent Cooper, AIA
Message 13 of 16
htemizel
It's great. Thank you very much sir.
Message 14 of 16
ErwinMoore
The O/P has a valid question that is being ignored here. Any block that is inserted should provide a prompt for replacing, and he is pointing out that he is not getting that prompt. The provided work-arounds do not address the core issue. I have several machines and one of them has the problem of not prompting to replace. All of my other machines prompt for replacement. Please, provide a solution to return the replacement prompt
Message 15 of 16
pendean
Community Legend
Community Legend
@ErwinMoore wrote:
one of them has the problem of not prompting to replace.... .
How do we all replicate that over here please? Remember, we are all end users just like you. Autodesk Support is elsewhere, through your accounts page.
Is this a sudden new problem for that one user? or has always happened for quite some time?
Or is it file specific? or all files?
Which method of "insert" are they using? And everyone else?
What is unique about tat one AutoCAD compared to everyone else? Location, VPN, where files are stored, mobile vs desktop?
Where is the source block coming from?
Did you reset that AutoCAD program yet? Or restart the PC?
Message 16 of 16
RSomppi
Apparently not as the OP marked a solution. Sometimes it's more about getting what you want instead of how you get there.
