DRIVER_POWER_STATE FAILURE when using Autocad and Autocad Architecture.
Hello, I am having issues using the Autodesk products Autocad 2019 and Autocad Architecture 2019. The programs open but then they crash and I get a blue screen with stop code: DRIVER_POWER_STATE FAILURE . I did not have this problem 1 month ago. Any suggestions.
vinodkl
Check these Threads:
https://forums.autodesk.com/t5/autocad-forum/driver-power-state-failure/td-p/6658811
https://forums.autodesk.com/t5/autocad-forum/driver-power-state-failure/td-p/5992475
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
did you try looking up the error code on the internet?
you will see this is not an Autocad problem
pendean
Community Legend
Community Legend
Take your computer in to a repair shop before you lose everything: you have a serious system level problem.
