Drive Connection Issue
Am getting the following error:
"The drive or network connection that the shortcut "AutoCAD 2016.lnk" refers to is unavailable."
Please help ...
Steven Jackson
Alfred.NESWADBA
looks like the ACAD.EXE is erased or moved away ... or this shortcut/icon was copied from a workstation where AutoCAD 2016 was installed, but it is not installed on your workstation.
With a default installation start Windows Explorer, change to folder
C:\Program Files\Autodesk
and search for a folder "AutoCAD 2016", if that exits, go into the folder and search for a file "ACAD.EXE", if that exists, double click it and see if it works.
If the folder does not exist, start Windows control panel ==> Programs and Features ==> and see if AutoCAD 2016 is on the list of installed applications. If not it's probably uninstalled.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
That appeared to be the issue; however, I've deleted the shortcut icons and
restarted my laptop several times.
It continues to appear that the application will not load on my laptop
because last year I installed this application onto an external hard drive
(that's now lost).
Is there a registry location that may be referenced that I need to delete as
well?
Alfred.NESWADBA
Not a good decision, AutoCAD is not a so called portable application
So I guess you need now to uninstall (if the uninstall works) and if the uninstaller does not work you need to do a lot of cleaning work, because some folder on C: as well as registry content exists and has to be cleaned before you can start a new installation.
Let me know if you have some questions to that ... and good luck!
- alfred -
PS: please don't install AutoCAD again on an external drive, that does not work well
Alfred NESWADBA
I have learned a valuable lesson; that I should have realized over a year
ago.
I vaguely remember there was a post that identified how to do a "clean"
uninstall (including registry entries) and then reinstall, but cannot seem
to locate it.
Can you point me in the direction that I must take now so I may install onto
my laptop..
Thanks again..
Alfred.NESWADBA
Hi
there it is >>>click<<<
- alfred -
Alfred NESWADBA
