DrawinI am g a rectangle with dimension on an opening
Hello, I am trying to draw  rectangles in openings created for Window and Doors but each rectangle I try to draw appears in another place entirely. Then I turned of the Osnap, still the same. What should I do?
you need to describe this better...
Patchy
Take a snapshot of the screen to show what happened.
Also the snapshot of the screen after you hit the F2 key
would be helpful.
DentonYoder
I couldn't really tell what he was asking, but a quick thing we used to do 30 yrs ago, was draw a rectangle 36 x 36, and copy it all over the place.... then hit trim and remove the wall or extra box pieces, but it was hard to get the doors 4" off the corner... So we would offset our box out 4" and copy both boxes, snapping to the corners... then delete the outer box before trimming and you force the door 4" from the corner...
SAPER59
Tell more about what are you doing, otherwise is difficult to guess and give you a solution
