Drawings Converted from Rhino Software
kgarrard.vmelectrical
Greetings To all we have a client that has been using Rhino software to model a project we are now involved in, upon conversion to autocad i only see about 50% of the drawing, meaning i see door swings, and walls randomly, some things are totally invisible and i only see them if the pick box happens to come in contact with them. and these things i cannot select. i have been looking for a certain graphicsconfig command (which will allow me to select a few different options to make the drawing more visible and workable) but i am unable to locate it this project is still in the early stages but i need an solution rather quickly. So needless to say any assistance will be greatly appreciated and absolutely accepted. Thanks in advance for your time and consideration. i am operating aotocad 2009 again Thank You very much
tcorey
Can you post the file?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
nothing seems to be working i keep getting the message that the file exceeds 25mb so i have taken the smallest element to send and still that is too large i am ope to suggestions as to how i may be able to transfer the file
tcorey
Use BE (block editor) to edit the block call Ephiphany-TB revised. Change the colors of all objects to something other than Bylayer. Exit block editor, saving your changes.
Tim Corey
Redding, CA
Hey TCOREY BAM thats it man!
 i appreciate that very much
solution accepted.
Thank You
now if i may i still have a problem with plotting being inconsistent and its always the title block
wierd stuff like the sheet number will be e-2 the e the dash and the bottom part of the 2 will print or every other letter in the engineers stamp will not plot. this is old jobs and new jobs none of the drawing settings have changed. i keep think maybe because autocad is so old    2009 this started several years ago ( when our autocad was a few years younger) and it is getting progressively worse and i have some days when everything plots exactly as it should.
i dont know what example i can send as i have no idea when i will get these unacceptable results
any thoughts?
thanks
keven
Hey guys I apologize i thought i had left a thank you message i did however not do the acceptance of solution.
You help was major and i would probably still be stuck if not for your expertise. And again Thank You Very Much
kg
