AutoCAD Forum
DRAWING TABS AT TOP OF SCREEN
2 REPLIES 2
poczatekb
467 Views, 2 Replies
Hi thanks in advance.
Autocad 2018 (UP TO DATE)
For some reason i can only see 4 drawing tabs at a time.
If i have 5 drawings open.
Is there a setting that changes this?
Use to be I would have all the tabs i wanted, they would just get smaller as I opened more drawings.
Everything I find is for not drawing tabs at all
See below drawing tabs circled in red, 5 drawings open but only 4 tabs show up.
2 REPLIES 2
imadHabash
in reply to: poczatekb
would you please check from your Autodesk Desktop App that your version is updated ?
also ... can you make a screenshot for your issue ?
Imad Habash
imadHabash
after you attache the image .... i notice that you have a CAD dwg's with long names . for that ... look at the same file tab location for a small arrow that will take you for the rest of your opening files OR you can try Ctrl+tab
Imad Habash
Forma Design Contest
