>> Printing to the PDF Creator still has the same result.
Well, as suggested, PDFCreator has multiple profiles, try a different one (or more).
After print from AutoCAD is finished the PDFCreator window appear with the question about title, profile, name, ... There you can choose the profile.
>> It works when I printed it out in PDF.pc3
Do you mean "DWG to PDF.pc3"? If so, compare the size of the PDF and you'll see that this one creates smaller files (by default) with the same quality, so no need to use any third party product. Or is there any reason why you use PDFCreator?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2026------------------------------------------------------------------------------------
(not an Autodesk consultant)
