Drawing semi-freezes
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Occasionally my drawing will partially freeze (for lack of a better description) where I can still save it, exit block editor, select objects, and delete objects... But I cannot perform any commands such as bedit, or move, or line, etc. If I double click on a block, it will highlight the block as if I single clicked it, but it will not open the block editor. If I select some geometry, I cannot un-select it. Clarification: I can unselect it by telling autocad to do something with it, such as copy or mirror or move. THEN it is all instantly unselected. (this is my quick test to see if this quirk has turned up again)
The only way I have found to get around this is to save the drawing (thankfully), close it, then reopen it. Sometimes the quirk reoccurs several hours later, or sometimes it reoccurs as soon as one or two commands later. But once it happens for a drawing, it is bound to happen again and again. Some days are worse than others.
I'm not losing any work, just time and trains of thought while I deal with it over and over -for the last several years. It's a drag.
Any suggestions?
(windows 10, Autocad LT 2020)
EDIT: I have been able to open the Edit-Block-In-Place, but it still won't let me do anything. In the command window, when it wouldn't let me move the geometry (in edit-block-in-place), it replied something about a locked layer. ...But all my layers are unlocked.
I'll insert a screencast if I can figure out how...
